Door openings not on 2D plan
LightBringer
I’ve created some door openings in Archicad, but they are not appearing on the floor plan.
I would like the openings to display with dashed lines, as shown in the attached picture.
Could anyone help me resolve this issue?
Thank you!
3 REPLIES 3
cuba
It is possible to customize this when you use an empty opening:  (sorry dutch version)
Apple M1 Max 32 GB Ventura
AC27
LightBringer
Thank you for your answer!
Where can I find these settings?
I can only see:
cuba
 Select the element you have and use the arrow to make it an empty opening. This is a different object than the objects in the library.
AC27
Setup info provided by author
