v13 GDL objects not opening in v12
Hello, This is probably pretty trivial & apologies if its been on before.
I have created some objects in v13 which arent even visible in loaded v12 libraries. Therefore not available in v12.
when dragging & dropping from explorer the error message:
"Drag & Drop did not succeed"
"Either the dropped object is invalid or the web pluginversion is outdated"
Can you please help me?
1 REPLY 1
You can't use V13 objects in V12.
They arn't backwards compatible.
