vertical door operation
David Bearss
Am looking to show the door tracks for an overhead door to run vertical rather than horizontal. Is this something that is blatantly obvious that I am missing?
David Bearss
Archicad 28/Windows 11
Alienware 17 R5
i7 2.4 GHz / 16 GB ram
6 REPLIES 6
David Bearss
I am looking to run the door tracks vertical rather than horizontal. Is there a way with my antiquated library parts? Like something in the picture.
David Bearss
Alienware 17 R5
David Bearss
Or this?
David Bearss
Alienware 17 R5
David Maudlin
David:
I don't see an option for this (D1 Garage 4 11). Based on your photos, you could make these with TrussMaker and a Beam at the top, saved as a single library part; but this would not be part of the door so would need to be placed separately.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Complex profiles would work well too.
Jared Banks, AIA
Shoegnome Architects
David Bearss
Modeling something will be easy enough. Was just wondering if I was missing something in the library. Odd that there isn't something as popular as these are here in the US land of big boxes. Thanks for the replies.
David Bearss
Alienware 17 R5
DaveOlufs
Dave,
I don't believe you're missing a part, GS has not developed proper OH doors.
While I've just loaded AC16, previous versions of AC, v12 thru v14 did not have a properly configured OH doors. These doors actually fit within the door opening, not covering the opening as standard for OH lift or roll-up doors.
In v15, GS introduced a track system that was what one would see in a standard residential garage door and still sat inside the wall opening. For commercial applications this simply was not functional. Your photos of overhead doors have hi-lift tracks which are quite common in my work but I've not been able to find or configure the right parametric settings for it. Again, I don't believe GS has developed those types of tracks...
Regarding Jared's comment, to model it... that is doable but IMHO the overhead doors within AC should include parametric door tools that replicate real-world situations... Maybe it's in v16 and I'll soon find out.
Dave Olufs
Just 4 Measure, Ltd
iMac Pro 3.2GHz Quad, 32GB, OSX 10.13.6, AC-5, 6, 6.5, 7, stopped for a few years--started again with 12 thru 17, 18 or 19 didn't work, then 20, 21, now skipped to 23. Started in 1976 hand-drafting ink on mylar...
