vertical sliding window with 3 sashes
Hi, can anyone tell me how to create a vertical sliding window with 3 panels? Ie a single hung window but with 3 sashes instead of 2?
1 Reply 1
Steve Jepson
just a thought, but what if you started with D3 Sliding 01 23 > moprh>rotate... save as window ?
It works ok. But be sure you size the door properly first, and configure the fame size and other options like the Casing first . Also, since it will be missing the casing on the side( bottom of the door) you can split the window/door/morph - mirror a copy for the other half, then use the Union morph function to make it all one unit. It will look something like this
Something like that might help if you want to make your own. Otherwise you can try searching for a Triple Hung window - if this is what you mean https://www.revitcity.com/downloads.php?action=view&object_id=4140
https://www.cadblocksfree.com/en/triple-hung-window.html[attachment=0]2020-05-22_16-12-
