LeeJaeYoung
what should I use for storm drains and integrated drain traps (sewage pipes + floor drains)?
For balconies without pipe shafts, use an integrated bath trap (sewage pipe + floor drain) as shown in the photo. And the circular sign below is a storm water pipe coming down from the rooftop.
Where can I find storm drains and integrated drain traps (sewage pipes + floor drains) available in ArchiCAD?
Where and what should I use for storm drains and integrated drain traps (sewage pipes + floor drains)?
2. I would like to add a wall-mounted faucet to the Tap.
3. Is there a way to erase the horizontal line inside the circle from the square drain?
4. Currently, everything is processed only with 2D symbols.
AC27 on window 11
0 Replies 0
