when the morph is created the handrail design, how to save the gsm file or gdl
I created the design of iron grill handrail with morph. When this design is used in spiral stair, how do i save or others.
Guru
Which version of ArchiCAD?
In 21 / 22, you should be able to save your railing in 3 parts, a Complex Profile for the handrail, a Railing Post and a Railing Panel. Each of these can then be selected in the relevant parts of the Railing Tool.
Ling.
For the railing post (this includes balusters), you 'Save Selection as Library Part'.
For the toprail, handrail and other rails you use a complex profile.
Here is a Helpcenter article for creating custom posts.
https://helpcenter.graphisoft.com/knowledgebase/75601/
