rob2218
where on the GS website can I find the library files for AC20, AC21 etc.?
where on the Graphisoft website can I download and install the AC20 library and the AC21 library?
I'm in need of creating PLAs and sometimes the PLAs wont save everything...so.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
5 Replies 5
Steve Jepson
https://www.graphisoft.com/downloads/archive.html
But does not have 21 library there
https://jepsondesign.sharefile.com/d-se6af7f36ef844aa8
I don't think you can download just the libraries for each version.
I am pretty sure you have to download and install each Archicad version to access the library.
So if you already have them installed then you already have those libraries in each of the installation folders.
Lingwisyer
Guru
We have saved a copy of each of the AC libraries that we have used to a shared drive so if need be we have them on hand even after uninstalling old versions.
Ling.
rob2218
Can you please explain in detail how you did just that?
Saving the copy of each versions Library please.......that would help tremendously.
Is the Library saved out as how? LCF file and how?
what's the process for doing that?
i>u
Edgewater, FL!
SOFTWARE VERSION:
It is quite platform independent:
go to the folder where the AC version You want library to backup is installed
on pc it is by default in Program Files\Graphisoft\
and just copy the "Archicad Library XX" folder to Your safe location... just that.
Piotr
PS I usually backup the whole AC folders (especially when there is an update - just to be able to step back without installing if the update is a lemon)
