2009-12-03
02:46 PM
2023-05-24
10:56 AM
Rubia Torres
2009-12-03 06:51 PM
Achille wrote:That would make too much sense
Is there a reason why the "empty opening" doesn't have the cavity closure option?
2009-12-04 02:10 PM
2009-12-04 06:05 PM
Achille wrote:Yes, there is one. Empty openings -- which come via checking Empty Opening button in the d/w settings -- are built-in in ArchiCAD itself and they should be as simple as possible to give a real quick opening solution. They started from an actual hole in the wall and got a bit more complicated over time. All the cavity closure infrastructure is way too complicated to get into the built-in library section.
2009-12-04 07:05 PM
2009-12-08 12:26 PM
2009-12-08 03:01 PM
Achille wrote:That's a whole other story. Don't get me started on that:) You won't have window-like or door-like curtain walls soon. For now, there is one workaround - place an empty door or window and a curtain wall. I know it's not perfect but it works...
Maybe you could also give a look to the cavity closure regarding the curtain wall?
I mean the same should happen when connecting a Curtain Wall to a Wall.
