windows & doors dimensions
there are about 50 doors and windows in the drawings....i tried to select all the doors and windows so to disable the dimensions for for the doors and windows but nothing change. so i have to go to each door and window to disable the dimension. then the client wants to see the dimensions of the doors and windows, and i had to go to each door and window again to enable the windows and doors dimensions!
is there a better way?
ac7r3/xphome
2 Replies 2
__archiben
in your display options you can choose to show windows and doors with or without dimensions . . . see attached screenshot.
may have saved you a little work, eh?
~/archiben
b e n _ f r o s t
thanks archiben......somehow i knew archicad has something like that but just didn't know where to look for it..thanks!
