windows
hi, how do you make a window follow the curve of a building?
thank you!
10 REPLIES 10
Srinivas
Look for the W M Curved window. In the Window Settings dialog box, change the upper left pop up to "Find Library Parts" and enter "curve" for the keyword.
Add your AC version in your signature
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
im on version 12, sorry šŸ™‚
and thank you
Srinivas
Here's a recent discussion on curved window for version 12, this will be of help to you.
ArchiCAD Service
Mac, Windows 11
thank you
the curved window in that post just makes a hole for the window which follows the curve but the glass stays flat.
Srinivas
Haven't tried the window in that post, but you can use the window in the ArchiCAD library.
ArchiCAD Service
Mac, Windows 11
if i use that window its fine standard, but if i make it wider then it does as shown in that photo
Srinivas
what problem are you having in making that window wider?
ArchiCAD Service
Mac, Windows 11
on mine the frame follows the buildings curve but the glass stays
straght..
