F. wrote:
selfgdl.com - Update to GDL version 1.556 (ArchiCAD11) is online.
It has not been a lot of work to do. Most was updating the references. 😉 Some minor interesting global parameters and a few commands to modify the wall out of an opening object. See "GDL_NewFeatures".
Hi Frank,
Have you noticed that GLOB_INTID is no longer used in version 11.
For existing old files opened in version 11 or items copied & pasted from old files will return a value.
But any new items placed in version 11 will return a 0 (zero) value.
As you have noticed there is now the new GLOB_INTGUID that needs to be used.
So all of us that use the old GLOB_INID in our scripts had better start changing them.
Thought you might like to know so you can update your website.
