zone stamp context sensitive
Frank Beister
I know, we have discussed that once anywhere, but maybe someone has a new idea:
I want a zone stamp to react (print out more or less information) on the environment. I have to layer groups, showing both the same stamps. One should be with, the other without the area information. Last help is certain pen, which I can turn to white. But that's not the best way, I think.
3 REPLIES 3
Hello Franck,
Does a Zone sensitive to another ? If it is, may be this is your solution…
Eric Wilk does an object for me that is "sensitive" to the zone where it is placed
request ("Zone_relations","",nom_zone,code_zone)
if nom_zone="Plafond" then
line_type "Tiret 1"
fragment2 1,1
line_type "Mixte court 1"
fragment2 2,1
else
line_type "Continu"
fragment2 1,1
fragment2 2,1
Hope this helps
Frank Beister
Thanks Frédérick, but this is not, what I need. The request returns only if, or what kind of zone stamp is placed in the area of the object that contains the request. There is no global switch inside the command.
Yes, I think there are several more GDL Global Variable that would be needed in order for this to work. Would be nice though.
