Array
I'm making a panel system that can have multiple heights per panel and any number of panels. So I was looking at the array tool in the parameters list.
If the user wants x panels how do you set it up so only x height inputs come up in the array values?
Frank Beister
You can not define a dynamic array in the parameter list. But you can define it with maximum expansion and write a UI-Script, which responds to a adjustable Size. The rest to the maximum keeps unused.
You can enter the array by the UI_INFIELD{2} command.
