2023-06-19 11:03 AM
I have a hardware license key for ArchiCAD 21 and last week I opened LMT and I saw I can update the license to ArchiCAD 22... I did that and now on LMT I have the license for "Archicad 22 International Commercial Single License"
I installed 22 and when I launch it, I select "I have a Commercial License on a Hardware or Software Key" and then I have only two options, to download a software key or to activate an emergency license.
I don't have a GS ID with a license, only the hardware dongle. I have created an GS ID only to post this.
ArchiCAD 21 is working but there's an annoying bug and I was really hoping I can use 22.
I am out of ideas for how to resolve this issues. Any recommendations would be appreciated.
Solved! Go to Solution.
2023-06-19 11:27 AM
Did you install the INT version of 22?
If so it should work with the license you have.
If you downloaded and installed a different language version, that may be why it is not running.
2023-06-19 11:27 AM
2023-06-19 02:01 PM
Thank you! I checked and I was using SWE version. I installed the INT version and its working fine!
Thank you again!
