furtonb
Unable to access CodeMeter driver - macOS Ventura
After updating to Ventura, my software key stopped working.
I've tried reinstalling LMT, but no luck so far, I've granted full disc access, and tried to see if something is blocking it.
This is the only window that I can get to after opening LMT:
Archicad is obviously not usable and I can't retrieve the key from this machine anymore.:)
odv.hu | actively using: AC27-29 INT/HUN - multiple builds | Rhino6-8 latest build | macOS @ apple silicon / win10 x64
1 Solution
Lee Hankins
Have you tried downloading and reinstalling the latest codemeter driver from the Graphisoft website?
https://Graphisoft.com/downloads/protection_key
there’s a driver on that page you can download and install.
If you didn’t upload your software key before upgrading to Ventura you’ve likely damaged it and it will need to be repaired.
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
Go to post
3 Replies 3
Lee Hankins
Lee Hankins
macOS Tahoe (26.0)
furtonb
Thanks Lee! It worked. I tried with the latest (?) License Manager Tool installer – which I presumed should've updated the CodeMeter driver too, but directly installing from your link made it work again.
Tuloko77
Worked for me as well, glad I found this thread. Thanks!
