Archicad Reverts to Educational Mode When I Open It
Hello All,
I just purchased a professional subscription to Archicad. I set up my license key in the Graphisoft Installation Manager as directed. However, when I attempt to open a new file, it automatically reverts to the educational version of Archicad, which I have been using to learn the software. I need to be able to run the software in professional mode. I have already deleted all Graphisoft/Archicad files from my computer and redownloaded the software. What do I need to do?
Please note that I am not attempting to convert educational files to professional files.
Thank you
Eduardo Rolon
When you open a file that was created in the EDU version in the Commercial it will always switch to EDU mode and it will remain until you open a regular non-EDU file. It could be that you selected a template that was saved as EDU or trying to open with "previous settings" and it is defaulting to EDU.
Try choosing a commercial template from the list to see if it goes back. If not then try doing a new and reset.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
