Licensing
About all sorts of licenses, their management, Graphisoft ID, Graphisoft Store, License Manager Tool, etc.
Archicad 22 License key
e_cecchel
Hello, I have a problem in getting a license for Archicad 22.
I am a University student and I have already registered to get an educational license for Archicad, however I only have the option to receive it for the latest versions of the program (27-28). So, I have already successfully installed Archicad 22 on my mac but I cannot find the license for this version, so I can only use the program in demo mode. This solution is not feasible for me because I need to use the program at full capacity for university. Does anyone know how to help me? Thanks.
Operating system used: Mac Intel-based 10.14.6 Mojave
3 REPLIES 3
There is no education version for 22 any more, that was 6 years ago.
28 is the current education version.
Maybe if you get a license for that you may be able to use 22 as well with the same license, but you won't know that until you try it.
But why would you want to use 22 when you can use 28?
I see that @e_cecchel mentiones "10.14.6 Mojave" as his operating system, so the answer could be quite simple:
Archicad 28 doesn't support macOS Mojave at all.
Just in case, macOS versions supported by Archicad 28:
  • macOS 15 Sequoia
  • macOS 14 Sonoma
  • macOS 13 Ventura
Versions macOS 10.x are not supported.
George
Good point.
Sorry, I am not a Mac user.
I would still apply for a 28 licence and then try that license number in 22.
I read in another post that EDU licenses can run older versions just like the commercial licenses can.
Setup info provided by author
