Grubenstein
Can't Sign into Archicad Solo with Graphisoft ID and ArchiCad opening in Demo mode even with Dongle
Hi All,
I Can't Sign into Archicad Solo with Graphisoft ID and ArchiCad opening in Demo mode even with Dongle inserted. Dongle briefly goes green when inserted and then no light on afterwards. No red warning light.
Any ideas as can only openin drawings by finding the file and right clicking open with ArchiCAD (PC)
Thanks
Kevin
1 Solution
Grubenstein
Thanks Minh, Wierdly as I went to record what the problem was it has now decided to Log in!!!
Thanks for your time anyway
Kev
Go to post
6 Replies 6
MinhNguyen
Either the license is damaged or you actually installed the wrong Archicad version. Make sure you have the right version (both language and version number) installed for the key to work
BIM Manager - DKO Architecture - Archicad 28 on Windows 11
Grubenstein
Its always worked in the past nothing has changed. Wonder if the dongle is working as usually you can skip the ID login at the bottom??
MinhNguyen
If you're using AC25, I think I know the problem:
https://community.graphisoft.com/t5/Licensing/Graphisoft-ID-Authentication-in-Archicad/ta-p/304128
You need to sign in with your GraphisoftID to activate Archicad. You can create one for free, doesn't have to be connected with anything
Grubenstein
Hi Minh,
Thanks for your help. I am using 25 Solo and already have an ID as can sign into the website. Just when I try in Archicad it asks for email and password but when pressing the sign in button nothing happens
Thanks
MinhNguyen
My bad, yes this requirement started from AC25. Can you share some screenshots or video of what happened?
Grubenstein
Kev
