Licensing
About all sorts of licenses, their management, Graphisoft ID, Graphisoft Store, License Manager Tool, etc.
Cant open my archicad
An error occured in the following addon: OpenGL
This is the message i´m getting when I try to open my archicad.
Need some help quick because it´s really urgent.
Thankful for all help I can get.
/Andreas
5 REPLIES 5
You're not giving us much to go on. You should always supply your hardware specs, ArchiCAD version, operating system, etc. when asking for help.
The easiest way is put it in the signature info of your member profile.
Thanks for the quick reply, I am not so good with computers but it is archicad 11 student version. I don´t know how I can give you info about the other things you brought up because I don´t know where I will find it:
Thanks again
Windows XP is my operative system i guess
Andreas
Go to Start>My Computer> View System Information
Djordje
... and then compare that with Archicad system requirements found here:
http://www.graphisoft.com/support/archicad/system_requirements/
Most probably your video card does not have full OpenGL support.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Yes, it may be very common that your computer simply cannot handle such a large program.
