Licensing
About all sorts of licenses, their management, Graphisoft ID, Graphisoft Store, License Manager Tool, etc.
Convert lines to walls
I just got this drawing in dwg format that has walls as lines, Is there any way to convert lines to walls in Archicad?
Aussie John
Use the magic wand tool. Select the wall tool in the toolbox (one click) and hover the cursor over a line while holding the space bar. Click mouse. A wall will be created to the line (and any other joined at the end). In practise the DWG will have too many lines and will be joined at "inappropriate" places such as windows.
Cheers John
[/size]
yeah it does work! thanks Aussie john
