Licensing
About all sorts of licenses, their management, Graphisoft ID, Graphisoft Store, License Manager Tool, etc.
Details in plot file disappeared
Details in Plotmaker - AC9
Good Morning,
I am cramming for finals today. I created a detail plot file where I have about 36 details. I accidentally hit F1 and then Escape, the plot file closed and Graphisoft Bug Report came up. I open the same file and everything is gone. Is there a way to recover this file ?
Thanks.
1 REPLY 1
Djordje
Good Morning,
Thanks.
Yes, if you have a backup. See in the folder where you first saved it - there shoud be a backup file.
Have not saved it at all? Well, this is going to teach you to save. CTRL S, very quick.
If Archicad crashed, you might be lucky recovering from a scratch file.
Anyway, when you started the Archicad after the crash, it should have asked you whether you want to recover the file you worked on - unless your autosave was also off.
CTRL S CTRL S CTRL S ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
