Licensing
All about Graphisoft ID and licenses: Education, Demo, and more
SOLVED!
Dimension offset issues
Hi there, I apologise if this issue has been addressed before although I couldn't seem to find any info in relation to it.
The problem I am having with dimensioning is when I select the linear dimension tool and then proceed to select all walls I wish to dimension, I then click ok and drag the offset to the side of the project, only 2 of say 5 walls selected show up on the offset although all the selected walls still have dimension nodes attached. Why is it I can only drag 2 of 5 dimension points? I've tried multiple setting changes and been at it for hours to try and rectify yet nothing seems to work, I've never had this issue on any other project. I'm still learning archicad so this may be an easy fix.
Any help would be awesome.
Thanks
1 ACCEPTED SOLUTION
Solution
Erwin Edel
Which version of ArchiCAD?
But at a first guess I would say your walls are not drafted completely at 90° angles of eachother.
Try labelling your walls with this label: https://bimcomponents.com/GSM/Details/21086
It will tell you if they are not at 90° angles.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
3 REPLIES 3
Solution
Erwin Edel
www.leloup.nl
Yep, that would be it.
Those walls aren't exactly horizontal.
Thank you for solving issue.
