Dims, stretching and revolve
Hi All
I hope this is the right place to request help, if not please scrub this topic and point me in the right direction..
I am working on a drawing and was wondering if it is possible to create a new line of custom text on a dimension. I want the dimension to read the distance and then under that text I want to add some custom text.
Also, does archicad have a revolve or lathe tool?
I believe it is possible to extrude with the aid of complex profiles and I have experimented and it seems OK.
Lastly, for this session anyway , is it possible to stretch multiple objects at once.
IE, If I had a wall that had several walls butting into it as well as some objects against that wall and I wanted to move that wall 2 meters back can I just stretch all the object nodes at once, rather than move & stretch each object individually??
10 years of autocad / studio max I'm finding this cross-over quite challenging...
All help would be appreciated..
3 Replies 3
David Maudlin
You can stretch walls and polygonal elements (roofs, slabs, meshes) with the marquee tool. The light marquee stretches the current floor plan elements, the heavy marquee stretches all the stories. Objects are not stretched with this method, just moved, so they will have to be adjusted individually.
HTH
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Djordje
... and the rest:
lathe and revolve objects (lib parts) can be done using the Profiler, that you should download (Help/Goodies) and install.
text under the dimension can be input manually, or you can use Alternative dimensions function and then edit the alternative dimension to what you want.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
That's excellent guys, the marquee worked a treat, & the profiler looks like it's exactly what I was looking for...
thank you very much...
