Licensing
About all sorts of licenses, their management, Graphisoft ID, Graphisoft Store, License Manager Tool, etc.
joint wall to wall or any other object
I would like to know whats the command that makes a joint between wall to wall or to any other object for ex.:scale??
Thanx
ET
1 REPLY 1
If I understand you question correctly then the answer is that Walls join correctly on Floor Plan only with other Walls, and Columns if they have the same Fill.
