Unfortunately SEO does not show in plan.
You can convert it to a morph and then it should show, but it will be harder to edit in future.
TIP: if you do that, keep a copy of what you used in the SEO in a hidden layer or off to the side so you can change it if needed later and convert to a morph again.
Or you have to add fills and lines in the plan so it looks as you want - that is what most will do.
