ā2023-04-07 11:30 AM
What controls the 3D cut surface display of a building material with surface set to general when used in a composite/profile? For a basic structure it is the elements last used override cut fill foreground pen but that does not seem to be the case for composites/profiles which revert back to black when the override is turned off.
ā2023-04-08 12:20 AM
Yes, for composites and complex profiles you can control surfaces by BM cut fill and you can override all by GOs.
