Floor plan cut plane settings?
Hi guys,
I'm on a roll this week!!... Thought I could just fit this last question in seeing as its Friday
I did a quick search before posting this thread, but found no joy there.
I want to draw up 3 horizontal sections through some kitchen cabinets and thought it would make sense to use the Floor PLan Cut Plane settings at three different heights to achieve this.
I have 3 plan views in my View map and thought I could adjust the FPCP settings individually and get my 3 sections.
However, adjusting the values doesn't seem to make any difference to what I see apart from the walls? I put 3 different height walls and they seem to register the change but the slabs I used for my cabinets shoe no change.
I tried to set a cup plane higher than the floor to see if the floor disappeared but it didn't seem to make a difference either?
Also I set the height to 750mm from floor and my overhead cupboards were still in view?
Have a great weekend
thanks Tony
5 Replies 5
__archiben
try switching your cabinet objects from 'Symbolic' to 'Projected' . . .
any good?
~/archiben
b e n _ f r o s t
any good?
~/archiben
Objects don't have that ability do they?
Only walls (including doors & windows), columns, beams and roofs.
__archiben
probably not! i wasn't in front of archicad and took a flyer based on windows and doors being able to . . .
you got me!
cheers
~/archiben
b e n _ f r o s t
Thanks for the repleys guys,
In the end I just created a detail of the cabinets and drew them @ the 3 levels in 2D..
Thanks for the input all the same...
Tony
Djordje
Barry wrote:
any good?
~/archiben
AFAIR some do ... but then, it might have been the 11 beta.
My brain is fried ... and too old ... 😉
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
