2021-01-12
12:31 PM
- last edited on
2024-01-29
12:43 PM
by
Aruzhan Ilaikova
Solved! Go to Solution.
2022-07-19 04:12 PM
Dear @Riccardo87 and @KenneyKim
Thank you very much for sharing the problem!
This issue can happen due to a system-wide block, preventing the connection from your machine to our services. Usually, this is caused by the hosts file.
To open this file:
- On Windows: the hosts file can be found at C:\Windows\System32\drivers\etc. You can open it with any Text editor application (Notepad for example)
- On macOS: open the Terminal on macOS (Finder > Utilities > Terminal), then run the following command (requires admin rights and password):
sudo nano /etc/hosts
Once the file is opened, please delete all entries in this file and save it.
After that, you will be able to access our services from your machine again.
Please let me know how it goes!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2022-07-19 11:17 PM
Thanks. It worked. Am now able to login
2022-09-20 04:28 PM
I have the same issue. When i try to login i get error site cant be reached. Grapghisoftid refused to connect. Maybe someone can help me?
2022-09-20 10:53 PM
Hi @Maybe-maybe,
Have you tried what Minh recommended above in the accepted solution?
Please let us know if his instructions were helpful in your case.
Community Expert | GRAPHISOFT SE
Did you get a helpful answer on the forum?
Give it back to the Community by marking it as an accepted solution!
