4 weeks ago
First year with Archicad. I noticed that it's not possible to find out the expiration date of my annual license. I know it only because I spoke with the provider, but I find it absurd that there’s no way to check it either through the software or on the website. It would also be appropriate to have reminders notifying you in advance of the upcoming expiration, about a month before.
Solved! Go to Solution.
3 weeks ago
Do you have a hardware dongle or a software license?
If you do, you can open the CodeMeter Control Center, then click the Web Admin button in the bottom right corner, which will take you to the browser and display info about the license, including the license expiration date (in the "Valid Until" column.)
I don't have a cloud license, so I don't know how it works in that case.
3 weeks ago
3 weeks ago
I can’t access the page, probably because of the office firewall. Anyway, I assume this is indeed the right solution. Thank you.
