‎2025-06-05 09:18 PM
Still down for me!!!
‎2025-06-05 09:33 PM
Try signing your Graphisoft ID out of Archicad and then back in again.
‎2025-06-05 09:39 PM
Did not work.
‎2025-06-13 06:17 PM - edited ‎2025-06-13 06:17 PM
same issue today.
I disinstalled LMT and Codemeter, installed the updated versions as suggested by technical support of both programs/drivers but nothing happened.
License is inaccessible
‎2025-06-16 03:37 AM
If your signature is correct and you are using version 27, have you installed the security update?
Make sure you select the correct language.
‎2025-06-16 12:53 PM
Thank you Barry. I'm giving it a try.
‎2025-06-16 12:58 PM
unfortunately nothing happened. Same issue. I log in into LMT but the program does not see any license although accessing the profile I see my software keys and where/when they were loaded. I think something happened with codemeter.
