pcedeno
Licenses Inaccessible
Still down for me!!!
6 Replies 6
Lee Hankins
Try signing your Graphisoft ID out of Archicad and then back in again.
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
pcedeno
Did not work.
alemanda
same issue today.
I disinstalled LMT and Codemeter, installed the updated versions as suggested by technical support of both programs/drivers but nothing happened.
License is inaccessible
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 11 Pro 64bit
Ultra 9 275HX 64GB GeForce RTX 5070ti
If your signature is correct and you are using version 27, have you installed the security update?
https://www.graphisoft.com/resources-and-support/downloads/?section=update&localization=INT&product=...
Make sure you select the correct language.
alemanda
Thank you Barry. I'm giving it a try.
AC27 latest hotfix
Win 11 Pro 64bit
alemanda
unfortunately nothing happened. Same issue. I log in into LMT but the program does not see any license although accessing the profile I see my software keys and where/when they were loaded. I think something happened with codemeter.
AC27 latest hotfix
Win 11 Pro 64bit
