Old Archicad file doesn't load correctly in v.22
Hey,
We've recieved our case for this semester. It's an "old" model created by a teacher, but when loaded into ARCHICAD 22 (student version) it seems to be missing walls and floors. The teachers have no clue why, can anyone help?
U can get the model here: https://1drv.ms/u/s!AlgM9QYKrJoGmeNQEgOe7rPYkzFlpQ
Thanks
4 Replies 4
Erwin Edel
The file is from AC16, however that shouldn't be a problem to open in 22.
It opens fine here (in 22), you need the library from AC13, which suggests this file has been going around for a while, maybe they should update the curriculum a bit
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
So it should be working fine for me? I have circled one of the obvious "flaws". Don't mind the strange color.
How do i get the AC13 library, can't seem to find it (they talk about migration when i search on goolge, and i migrated de model already)
Erwin Edel
Unless you have the original installation disks (highly unlikely), I would say there is no way to get them at the moment.
Your local reseller might be able to help, but your tutor should really fire up his old archicad and start migrating stuff forward. Or learn to archive files properly (pla format).
The purple checkerboard patterns are the missing texures due to missing library.
The holes etc would most likely be the windows and doors and such that are missing.
www.leloup.nl
In the "ARCHICAD Migration Libraries" folder there are folders for all previous versions from AC13 on.
You should load both the ARCHICAD 22 Library and any needed Migration Library.
