Test Results
Is 34% on the mock certification test pretty bad, considering I only know Autocad? I want to learn Archicad real bad. Then I want to take the test again.
4 Replies 4
In my opinion, 34% does not sound that bad at all if you never used ArchiCAD before. You should be able to learn it real quick and real well.
What is the time you use ArchiCAD?
I know the program many years, but I make any opening for myself about ArchiCAD about once a month
Author Message
R.A.M.
Guest
Posted: Sat Jul 23, 2005 6:45 am Post subject: Test Results
- What the test are you talking about? So, is there some kind of a thorough test of ArchiCAD? And if so, how it works?
(You've mentioned "mock certification test" - could you please explain what is this test for and where one can pass it? Is it just for self-training or I can get a certificate of klowledge of certain programs (perticularly, ArchiCAD)?
Go to the "ArchiCAD Competency Challenge" thread in the ArchiCAD+ forum section to get some background info (don't worry about the bogus scores talked about at the beginning, the problem has been sorted out), or directly to the challenge here.... http://www.graphisoft.com/community/certification/session.html
