2022-11-16
09:52 PM
2023-05-25
06:04 PM
Rubia Torres
Hi. I started this project on Trial because I was having some issues with the EDU serial number. They got it solved and now i need to continue the project on the EDU version but it won't open a file started on Trial. Does anyone know what I should do?
2022-11-16 11:18 PM
Speak with your local Archicad office/reseller and see whether the file can be converted by them. Technically from a users perspective, there isn't anything we can do.
2022-11-17 12:51 PM
I don't think it is possible.
Trial versions are tied to the specific installation and only be converted to full versions once you buy AC. If possible export to Revit or IFC and import into EDU.
2022-11-17 01:04 PM
Sent them an email yesterday. Hope they can convert! Thks
2022-11-17 01:05 PM
If I export to sketchup and import to Edu it will lose the Archicad properties. Do you know if the same happens with Revit or IFC?
2022-11-17 09:12 PM
IFC should keep the properties
