Licensing
About all sorts of licenses, their management, Graphisoft ID, Graphisoft Store, License Manager Tool, etc.
Trial do EDU convertion
eglantina
Hi. I started this project on Trial because I was having some issues with the EDU serial number. They got it solved and now i need to continue the project on the EDU version but it won't open a file started on Trial. Does anyone know what I should do?
5 REPLIES 5
Speak with your local Archicad office/reseller and see whether the file can be converted by them. Technically from a users perspective, there isn't anything we can do.
Nathan Hildebrandt fraia
Director | Skewed
AC6 - AC29 | WIN 11 | Ultra 9 285K, 3.7Ghz | 64GB Ram | RTX4000
I don't think it is possible.
Trial versions are tied to the specific installation and only be converted to full versions once you buy AC. If possible export to Revit or IFC and import into EDU.
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
Sent them an email yesterday. Hope they can convert! Thks
If I export to sketchup and import to Edu it will lose the Archicad properties. Do you know if the same happens with Revit or IFC?
IFC should keep the properties
AC28 US/INT -> AC08
another Moderator
