facing problem in 3D view generation of multi no. of GDL
can i compress the file size of a GDL object? then how, plz guide me in detail.
Dwight
This message indicates that you need more free hard disk space for Archicad to create its 3D model.
The fastest way to fix this is to buy a remote drive and tell Archicad to use it for temporary files - like the 3D model.
Otherwise, throw away your games and girly pictures and archive your old stuff on DVD to free-up your existing drive.
Dwight Atkinson
Djordje
Also, check your polygon count (the AddOn is a free download, go to the Goodies from your help menu)
Did you maybe use imported 3ds or dxf files?
If you need GDL models, check here:
http://archicad-talk.graphisoft.com/viewtopic.php?t=2434
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
