ā2023-12-07 11:30 AM
We're using softkey for our license and a hardkey for our 200 hours dongle.
1. Is it possible to change a 200h dongle to a softkey license?
2. Is there a better way to upload the license, then do it manually? For example, when Archicad is closing, the license will be uploaded..
Sincerely Manuel
ā2023-12-07 11:53 AM
Are you aware of the possibility to set up a network server containing your licenses?
https://help.graphisoft.com/AC/26/INT/index.htm#t=_AC26_Help%2F003_InstallGuide%2F003_InstallGuide-9...
Depending on the server-type you might need to get in contact with your local support
ā2024-08-23 10:07 AM
Yes, many of our customers switching to cloud-solutinos (small offices). Because of Archicad they still need kind of server;)
