Clean, trustworthy and easy to read - MEP documentation tips
If your MEP documentation feels cluttered or unreliable, you might be missing a few key tools in Graphisoft MEP Designer. This article shows how to use the System Browser, lengths, Model View Options, symbolic views, and labels to produce clean, trusted drawings.
See the full picture with the MEP System Browser
Use the MEP System Browser to review all systems in one place instead of hunting through views.
With the System Browser you can:
  • List all MEP Systems in your project.
  • Inspect connectivity to find breaks, wrong connections, or missing terminals.
  • Check system setup.
  • Review current calculation results (e.g. velocity, capacity, volume flow, dimensions) before moving on to documentation.
This makes it much easier to verify that the design is correct and consistent before you start producing drawings and schedules.
Use individual lengths for reliable quantities
For accurate quantities and cost‑reliable takeoffs, work with individual segment lengths instead of only overall route lengths.
Why it matters:
  • Manufacturers often supply pipes and ducts in fixed segment lengths.
  • Schedules based on correct segment lengths reduce manual checking and spreadsheet work.
In your model:
  • Make sure each pipe and duct segment is correctly modeled and split where necessary.
  • Use individual lengths as the source for schedules and lists, so the values on drawings match what you order and install.
Control what you see with Model View Options
Once your system is set up, Model View Options (MVO) let you fine‑tune how MEP elements appear in different documentation scenarios—without duplicating the model.
Typical uses:
  • Switch between detailed and simplified display of equipment and terminals.
  • Control visibility of small fittings and accessories for high‑level plan views.
  • Create view combinations that align with design, coordination, and construction drawings.
This approach keeps a single, coordinated model while giving you multiple graphical representations tailored to each drawing purpose.
Simplify plan views with symbolic 2D representations
For clearer, easier‑to‑read plan views, display MEP systems using symbolic 2D representations instead of full 3D geometry.
Benefits:
  • Pipes, ducts, and equipment show as clean symbols and lines, reducing visual noise.
  • Early‑stage and coordination drawings become much easier to interpret.
  • You can emphasize routing and relationships instead of detailed object shapes.
This is ideal for:
  • Early coordination layouts with architects and structural engineers.
  • Schematic planning and concept design.
  • Sharing simple routing information with project stakeholders.
Make drawings clear with Labels and Dimensions
To finish your documentation, add labels and dimensions so plans are self‑explanatory and require minimal verbal clarification.
What to label:
  • Pipes, Cable Carriers and Ducts with size, system, and medium.
  • Fittings and accessories with key data (e.g. type, flow).
  • Equipment with their system role or calculated values.
Use labels that automatically read MEP data—such as system name, calculated results, and key attributes—so any design change in the model is reflected on the drawings with minimal manual edits.
Dimensions complete the picture by clearly showing e.g.:
  • Offsets and routing clearances.
  • Pipe and duct spacing.
  • Critical sizes around equipment and access zones.
Highlight what matters with Graphic Overrides
Note for MEP Designer users: Some Graphic Override rules can only be applied and used in Archicad Collaborate. These rules (like transparencies) have no effect on model display in MEP Designer Studio and will not change how elements appear there.
Use Graphic Overrides to apply a predefined appearance (color, fill) to model elements by view, so you can simplify graphics and highlight what matters at a glance.
You can, for example:
  • Apply a simple gray fill to all walls to create a calm background that makes MEP routes stand out.
  • Show different MEP systems (heating, cooling, ventilation, electrical) in distinct colors.
  • Highlight critical zones (for example plant rooms or riser shafts) with stronger fills or outlines.
  • Emphasize elements with specific performance criteria (for example fire‑rated components or sound‑sensitive rooms).
In such views, it’s easy to read the MEP floor plan because the architecture is visually toned down while systems and key areas are clearly emphasized.
The element’s Info Tag lists the Graphic Override Rules in effect for this element, so you can understand why it appears with a certain color or fill.
Apply Graphic Override Rules
There are two main concepts when working with Graphic Overrides:
  • Graphic Override Rules
    Each rule defines which elements it affects (criteria such as element type, layer, classification, properties, or MEP system) and how they should look (override style: color, line type, fill, surface, transparency, and so on).
    Several rules can be active at the same time; if multiple rules match the same element, their order determines which style “wins”.
  • Graphic Override Combinations
    A Combination is an ordered set of Graphic Override Rules that you save and reuse in views.
    • In floor plan views, you can use a Combination that gives all walls a uniform gray cut fill and keeps MEP systems in clear colors. This creates a simplified, MEP‑focused plan and is available in Archicad Collaborate and MEP Designer Studio.
    • In 3D coordination views, you can use another Combination that makes the architecture transparent while keeping MEP routes opaque and colored. This helps you see systems inside the building shell and is available in Archicad Collaborate.
      When you assign a Combination to a view, all its rules are applied in the defined order to every matching element in that view.
Graphic Override Combinations are saved as part of each view’s settings, so every view can have its own dedicated override logic tailored to its documentation purpose.
Suggested GIF
  • GIF: On a floor plan, apply a “MEP‑focused plan” Graphic Override Combination that turns walls to gray fills and colors MEP systems; then switch to a 3D view and apply a “Transparent architecture” Combination to show see‑through building elements with clearly visible MEP routes.
Suggested GIF GIF 6: Choosing a Graphic Override Combination in Quick Options and showing zones or systems change color, then opening an element’s Info Tag to see the active rules.
Check slopes with On‑Screen Slope
Feedback Slopes are essential for the effective functioning of many piping systems. MEP Designer provides clear slope feedback so you can confirm both direction and value while modeling.
Turn on MEP Slopes at View > On-Screen View Options.
With MEP Slopes turned on:
  • On the Floor Plan, you see the direction and value of the route slope along the route.
  • For a selected route element, the Info Tag also displays the slope value.
  • In 3D and Section views, selected route elements display a green arrow to indicate the slope direction.
This helps you quickly verify minimum slopes, avoid wrong fall directions, and communicate intent clearly in views used for coordination and review.
Learn More
For deeper, step‑by‑step training on these tools and workflows, explore the MEP Designer Training Course in the Learn Archicad program on Graphisoft Learn.
Useful links:
