2004-04-19 01:05 AM
2004-08-26 04:23 PM
Scott wrote:OK - lets leave it at that then. I share your interest in other packages and the future of the industry as a whole, but I think it's better for all concerned if we take comparisons to other forums.
Thanks for the link to the older post of mine regarding plotmaker. I read through it again, and still don't see where it answered some of my other more recent questions.
2004-08-26 07:48 PM
2004-08-26 10:02 PM
Scott wrote:In answer to your question regarding PlotMaker, the flow of information is only in one direction. PlotMaker is primarily designed for arranging images on sheets, not managing the building model. It can automatically detect changes in the source material in layouts and redraw them accordingly, so moving between ArchiCAD (or other apps) and PlotMaker is quite fluid. You normally have them running at the same time, so there is no delay.
We had been discussing this in the "Other Products" forum here, but somehow this one ended up in the ArchiCAD topic area.
2004-08-26 10:56 PM
2004-08-26 11:30 PM
Scott wrote:Field-use is one part of the problem, but we also grapple with the legal implications of electronic documents. It's a real minefield. Electronic data may not be accepted as evidence in the same way as paper and ink, nor is the trail from sender to recipient as tangible.
I can appreciate that forward-thinking concept. I've often thought that we are not far off from contractors having computers in the field, on which they flip through views of the model to build the project.
2004-08-27 06:53 AM
Scott wrote:Considering that the discussion is not so much about ArchiCAD and Revit (the one in Other products is much more so), but does touch and explore the future of the industry, I decided to keep it here.
2004-08-27 07:26 PM
Scott wrote:Yes, AC has done this when printing to PDF since 8.0.
Not sure about AC, but Revit's callouts are already linked in the program, so writing them out as hyperlinks is automatic.
2004-08-28 01:17 AM
2004-08-28 05:36 AM
another Moderator
2004-08-28 11:52 PM
