2 pitched roofs with different angles
I am trying to model two pitched roofs with different angle so one has a lower eves level than the other. The geometry doesn't seem to work. Is there a way around this
5 REPLIES 5
it looks like it is working as expected. Stretch the roof on the left back to the wall.
Gerald Hoffman
In addition to what Steve indicated you may want to add a node on the roof edge adjacent to the wall so that you would only adjust the edge underneath the edge of the upper roof barge. Otherwise you will see a line on the upper roof.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 27-6000 USA
2019 MacBook Pro-macOS 15.0 (64GB w/ AMD Radeon Pro 5600M GPU)
Red
Have you "Split into Single-plane Roofs" (Right-click with roof selected)
Once you split the roof, you can edit them individually allowing you to extend one roof plane under the other.
Thanks,
Red
i7 8700k
ROG Strix Z390-E MoBo
64gb RAM
EVGA GeForce GTX 2080
_______________________
http://www.facebook.com/flatcreekdesignstn
http://www.sraarchitects.biz
Thank you for the replies, they are two different roofs and on the plan I have stretched it lower one towards the wall, however in 3D it seems it does not strict under the upper roof. perhaps I need to split the part that goes under the upper roof?
When you select the small roof do you see a little connection symbol?
If so then it is still connected to the other roof and will trim automatically the portion that is below the higher roof.
Click on that symbol and delete the connection then you can stretch the lower roof under the higher one with no problems.
