‎2011-02-17
11:00 AM
‎2023-05-23
02:51 PM
Rubia Torres
‎2011-02-17 11:01 AM
‎2011-02-18 02:41 AM
‎2011-02-18 11:05 AM
Peter wrote:1. No hidden lines or double geometry.
Could there be two walls or roofs in the same position? Is there anything on a hidden layer that could be affecting that junction? What did you use to form the wall to the roof; SEO or trim-to-roof? Have you tried using the other method, or re-doing your preferred method again? Any tiny inaccuracies like walls not quite at 90 degrees?
So many questions!![]()
‎2011-02-18 06:12 PM
‎2011-02-18 06:56 PM
Matthew wrote:I hope this isn't the case. While I primarily use the SEO function, the TTR function still has it's place and is very useful. I wouldn't want to see it go away.
TtR...is really an old feature and is likely not to receive much support going forward.
‎2011-02-18 11:18 PM
Erich wrote:Oh, I don't think it will go away anytime soon. Just don't expect improvements.Matthew wrote:I hope this isn't the case. While I primarily use the SEO function, the TTR function still has it's place and is very useful. I wouldn't want to see it go away.
