2014-01-18 02:01 AM - last edited on 2023-05-23 02:32 PM by Rubia Torres
2014-01-20 12:24 AM
2014-01-22 06:18 PM
2014-01-23 02:26 PM
2014-01-23 04:26 PM
David wrote:Hi David,
drexdis:
I think you should try the Morph Tool, the Shell Tool would be another option.
2014-01-24 03:51 PM
2014-01-26 02:06 PM
David wrote:David,
drexdis:
I am not sure that the Shell Tool can handle that type of form (double curve flattening to straight on one edge). I think the Morph Tool is easiest:
1. Draw rectangle in plan
2. Elevate 2 ridge points
3. Curve ridge and 2 side edges
4. Push/Pull top surfaces to desired depth.
2014-01-26 02:52 PM
2014-01-27 02:26 PM
2014-01-28 03:24 PM
drexdis wrote:In 3D, select the face and use the Modify Segmentation... command.
1. Is it possible that the curve of the shape to have more smooth transition ( in my case the curve i guess it is made of ~6 straight lines), is it possible to increase this?
drexdis wrote:Yes, once curved I could not get Push/Pull, so Drag a Copy the Morph face to create the lower surface, then add Morphs for the 4 sides, then Union or Group. I could not get a Solid Morph from this, but maybe with more work it is possible.
2. How do i give thickness to this? It is still just a face. Push pull doesn't show.
