3D Rotate slab tabletop from floor plan up to elevation
Flipping about XYZ to flip slab from horizontal to vertical for a flip-top tabletop...? ArchiCAD 14
3 Replies 3
1. Save the slab as Object and edit the 3D Script: ....http://www.archicadwiki.com/RotateObjectInSpace
2. Save the slab as Object and use "ROTATOR.GSM" to rotate it
Ralph Wessel
Try using OBJECTiVE. Referring to the attached image, you can tilt your tabletop in 2 simple steps:
  • 1. Select the slab and click the menu OBJECTiVE > Component > New Profile. Enter a name for the object, and check the options to place the profile and delete the origin item.
    2. With the new object selected, click the menu OBJECTiVE > Tools > Rotate, click to define the rotation axis, and enter the rotation angle.
    3. The object also provides rotation parameters, so you can freely flip it up or down.
Ralph Wessel BArch
Central Innovation
THANK YOU BOTH for all your help!
