3D View upside down ?? Help!
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2006-01-31 11:05 AM
2006-01-31
11:05 AM
I've imported a DWG and have started to trace the buildings however, when I go to the 3D view everything is upside down.
Is there any way I can orbit the DWG and trace on the other side so that the 3D view will be the right way? Any ideas why this is happening ?
Thanks
Jus
8 REPLIES 8
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-01-31 11:14 AM
2006-01-31
11:14 AM
Maybe when you import the drawing check the "Import as an GDL object" line and once inserted (if it's still "upside down"), open up the object with the GDL menu (File >GDL...) and just add roty 180 to the 3D script and save.
Probably not an ideal solution but it's the only one I see....
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-02-01 04:37 AM
2006-02-01
04:37 AM
Jus wrote:Where are you looking at it from?
Maybe it is just a wrong viewpoint.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
HP Omen
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-02-01 04:52 AM
2006-02-01
04:52 AM
Jus wrote:the DWG is a 3D object?
or maybe: you need to press one of the 3D window 'reset' buttons on the 3D navigation palette?
~/archiben
b e n _ f r o s t
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-02-01 02:10 PM
2006-02-01
02:10 PM
Upside down problem persist, if model is rendered from perspective top view (see attached screenshot).
p.s.: This is not DWG problem!
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-02-01 09:46 PM
2006-02-01
09:46 PM
Z.Bauer wrote:the distance between the camera and target is very very small - many this has the effect of flipping it over? bug for sure, but what happens if you use the 'look-to' button to increase the length of the viewpoint?
~/archiben
b e n _ f r o s t
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-02-02 05:41 PM
2006-02-02
05:41 PM
No, the DWG isn't a 3D object. It's just a DWG opened up in Archicad which I am using to trace in order to get a very simple model from.
I only noticed this 'upside down' problem when I wanted to insert a couple of objects and realised that when they appeared upside down that actually the model was upside down not the objects.
The reset buttons make no difference to it.
Example below.... shows an object inserted (circled).
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-02-02 10:00 PM
2006-02-02
10:00 PM
Jus wrote:do you have any cameras placed? and if so do they have a 'roll angle' of 180º instead of 0º?
regardless:
create a
running out of ideas . . .
~/archiben
b e n _ f r o s t
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-02-03 12:46 PM
2006-02-03
12:46 PM
~/archiben wrote:Same result if you use "look to" button.
...bug for sure, but what happens if you use the 'look-to' button to increase the length of the viewpoint?
~/archiben
