Change thickness of Cavity Walls
Good day,
I would like to know how can you change the thickness of cavity wall to have the following properties.
110mm Brick x 50mm Cavity x 110mm Brick
90mm Brick x 50mm Cavity x 90mm Brick
Thank you
Japie
Erika Epstein
Under the Options menu, find composites. Within this find the composite wall whose various thicknesses you want to change.
Keep in mind that this change will only affect this file. If you have or might want walls with the original wall thicknesses,
make a copy of the composite,
rename it
and then change the layer thicknesses as you have described.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Thank you so much Erika, I knew it have to be somewhere, it is just a question where to look.
