Learn more
3D Windows CUTS through everything.
Well Basically a new problem developed after I made a slab bigger, now it seems to cut through everything when I get close to it. Its kind of hard to explain, so I took several screenshots so you could see what I'm talking about.
5 Replies 5
RandyC
video card ?
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
RandyC wrote:
video card ?
I don't think so. Its fine with other projects, and like I said it was fine until I made the "ocean" slab bigger.
Ernest Atanasiu
can't remember the post where it was discussed, but if you make the ocean slab smaller, the problem might go away.
Objects too far away seem to cause this.
arch. ernest atanasiu
AC 10-29 INT/GER/FR on Win 10/ Win 11
Yes uisanata is right, it's the clipping plane of death caused by excessively long geometry. See here -
http://www.archicadwiki.com/Bugs/Model%20cut%20in%203D
Sweet, thanks.
