‎2005-01-04 01:24 AM
‎2005-01-04 05:05 AM
‎2005-01-04 07:36 AM
Jay wrote:I just use a wall 1.5" wide and .75" thick and trim to roof. If looks fine in 3D.
What is the best way to produce an material that can display in 3D (Internal & OpenGL) a realistic board & batten siding.
‎2005-01-04 02:44 PM
Steve wrote:Steve,Jay wrote:I just use a wall 1.5" wide and .75" thick and trim to roof. If looks fine in 3D.
‎2005-01-04 02:45 PM
‎2005-01-04 04:04 PM
‎2005-01-04 04:33 PM
What is the best way to produce an material that can display in 3D (Internal & OpenGL) a realistic board & batten siding.Others have sugested means of modeling the board and batten. It sounds like you are looking to apply a material to the exterior wall that will render correctly in the 3d window using open GL. A method I have used is to model some board and batten in Archicad and view in the 3D window. Save the 3D view as an image file and edit in photoshop color, brightness etc. Others are much more sophisticated in this so my methods are quite primitive. You might also search for textures that have already been made. There are a lot of free ones on the web and I am sure objects online will have something to offer.
‎2005-01-04 05:35 PM
‎2005-01-04 06:26 PM
‎2005-01-04 10:04 PM
Jay wrote:That was the prelim. In the rendering, I made the batts all one object. In elevation view I used the slab tool to make the batts 3/4" thick, view from the top and save as an object. The fascia, gutter, and soffit were made with the profiler tool. I just used the lines from my typical wall detail. The trim and fascia at the gable end are rafters. It takes very little time at all to model the trim. The custom windows were made by using the 2D drawing I got from the Milgard web site for that exact window. Same technique. Slab tool-Magic Wand, view from top and save as object.
Steve, yes nice work. Are you breaking the Battens at the windows and vents with SEO.
Your solution is more for the Finished product, seems time consuming. I would like a solution that I could use during early Design also to give a more realistic representation to the client for possible options.
If your fascia/eave detail answer is fairly extensive maybe you could start another thread and post the link here.
