Learn more
3D modeling
i need to create a 3D masonry chimney, and i know we can model solid objects in 3D but i don't know how or where to find it in the guide. i don't know what it's called. what would i search for?
wb
6 Replies 6
Steve Jepson
can you show picture of what you want to make ?
Erich
Perhaps you can find your answer here (the On Land site)?
These parts may also help.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
David Maudlin
Bob:
Take a look at Complex Profile Element in the Help files.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
My chimney, made of slabs, and conforming to the 2 5/8" brick height to make the brick joints look realistic.
Erich
I should say that to use the flue object I posted today, SEO it from a wall/slab/whatever you are using for the chimney core. It has a hidden operator to removed the necessary bits.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
Steve Jepson
Be sure you flash that
