3D text
3d TEXT
Where is it?
Doing a search in the 14-lib did not find it.
Is it right under my nose?
lec
Mine's in Archicad Library 14> Object Library> Basic Library> Furnishing> Decoration, found using the Find Library Parts option in Object Settings, using the keyword "text". (I'm guessing you put in "3D text" and that's why it didn't find it)
Thanks Stuart.
Yep, it was a nose thing,, worked like a charmed charm.
Silly me, thinking "3d text" search would work:-)))
Take care.
Be safe out there.
lec
Oliver Dentan has made really fine objects,
a curved + multiline 3D text object can be
found here <http://archicad-talk.graphisoft.com/viewtopic.php?p=143709>
Refards, Juha
