Kevin11
3D view moves when switching windows
When i try to save the shadows and poligons separately, every time i switch between the pages, the marqueed area moves a bit. Not even using the mouse, just the ctrl+c command, but still. I can't save this way a single view to work on in ps.
3 Replies 3
Bonjour  @Kevin11 ,
It is hard to give you an answer without these informations :
- Archicad version
- Hardware configuration
- OS
- and some print screens
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
Kevin11
Hi @Christophe Fortineau
_i am using 26 EDU version
_AMD Ryzen 7 5800H with Radeon Graphics 3.20 GHz and GTX 1650 and 16GB RAM
_64bit win 10
between the two pictures just switched the window to 1. level and back
Do you use a view with parameters ?
Could it be the mouse or the mouse driver ?
I do not know about EDU version but I know you should update your Archicad to remove any bug or other strange or even counterproductive behavior of archicad and caused by the Windows update or by specific hardware.
Christophe - FRANCE
